How to factory reset
Postby Michi » Fri Aug 08, 2014 1:25 pm
I made a misconfiguration in "TVheadend" and I looked myself out.
Is it possible to do a Factory Reset of MOI+ ?
Thanks for your advice.
Michael
Michi
Re: How to factory reset
Postby elchubi » Sat Aug 09, 2014 8:03 am
log into moi+ using ssh and
rm -fr .hts/*
That will take care of your misconfigured tvheadend
elchubi
Postby moiplus » Sat Aug 09, 2014 12:17 pm
Besides this specific solution for a misconfigured Tvheadend installation, how do I execute a general factory reset ?
I've already tried switching off and turning on while pressing the reset button: that did not work.
Thanks for a pointer in the right direction :)
moiplus
Postby moiplus » Sun Aug 10, 2014 2:35 pm
Problem solved!
A factory reset is performed by reloading (at least) the system file: MOI2921_fs.bin, all settings will be reset to initial.
1. Download MOI2921_fs.bin) from: http://www.tbsdtv.com/download/;
2. Copy MOI2921_fs.bin to a USB flash drive;
3. Make sure your MOI+ is powered off, connect the USB flash drive to it, and then power on, the update will start, on the LCD screen it displays:
- "Welcome MOI+"
- when updating the system, it shows the system loading progress in percentage (%) and "Reading, please later...";
4. After the update completes, the IP address will be displayed on the LCD screen (make sure the network cable is connected).
moiplus
Return to MOI+
