xbmc not starting with network
Postby DrFunk » Fri Aug 08, 2014 9:55 am
Just received my Matrix today, booted up first time with ease. :) I accessed the boot menu from the Tbs splash screen, set up wlan0 successfully. Now Matrix gets passed the splash screen but won't start xbmc. I have to perform hard shutdown via power button. No change after a few tries. Same behavior with eth0 plugged in.
If I try to setup eth0 while unplugged (force an error), then xbmc can start again, but no IP in system information. I plug in eth0 and finally get an IP.
Any idea why xbmc doesn't start with networking? What should I do to fix this?
DrFunk
Re: xbmc not starting with network
Postby DrFunk » Sat Aug 09, 2014 11:28 am
Cancel this. Solved by reruning wlan0 setup and test again... It kinda solved itself.
DrFunk
Return to Install and setup
