Error Code 5
Error Code 5
Postby newuser » Thu Jun 19, 2014 9:36 pm
I have just installed this card and the drivers. DVB Dream gives me an error loading DVB hardware (although the two tuners are listed), while the other software does not return any picture at all. I am running Windows 8.1.
Is there anything I can do to check if the card is functioning correctly? The Device Manager says that it is working properly, but this is not always an accurate reflection.
Thanks for your support!
newuser
Re: Error Code 5
Postby captainigloo » Thu Jun 19, 2014 10:59 pm
Same probleme with 5281 on w7X64
Sébastien Joly AKA CaptainIgloo
captainigloo
Re: Error Code 5
Postby newuser » Fri Jun 20, 2014 3:39 pm
Sorry, I should mention that it is w8.1 64-bit.
newuser
