TBS6981 Card only produces a partial Channel list
Postby Hersh » Tue Jun 17, 2014 11:43 am
I have been struggling with this issue for over a year now. I can't seem to get this device to pick up the channels my TV receiver picks up. It only shows a partial list. I am now considering purchasing the 6985 model, but I can't justify spending even more on these devices when I can't get the one I have to work.
Today was the last straw. I bought an amplifier thinking that perhaps the PCIe card is not providing the voltage to control the switch for horizontal or vertical selection. I purchased one with 20V power adapter. No change. Prior to this I even bought a 4-molex connector adapter, replaced my power supply and connected them. This also made no difference. I had a non-standard mini ITX-esque tower from Gateway so I was limited in my power supply selection.
I have now purchased a brand new computer with a standard sized ATX tower. And yet, I still have the same problems.
What gives?
I am in North America and I have my dished pointed to Galaxy 19 (97 W).
Hersh
Re: TBS6981 Card only produces a partial Channel list
Postby steven » Tue Jun 17, 2014 4:15 pm
Hi Hersh
Can you give us more detail information,such as which transpnder's channel you can not receive?
and which soft you are using and so on.
Postby steven » Wed Jun 18, 2014 3:09 pm
Hi Hersh
These transponder are normal,and if you can receive some transponder,
Can you have a try move your dish to the right position ,maybe the signal is not very well.
so you missed some transponders.
Postby Hersh » Thu Jun 19, 2014 8:04 am
But as I explained in my initial post, I have a receiver connected to the same dish. It receives all the channels just fine, so signal should not be a problem. I have adjusted the dish numerous times and even moved it to the top of the roof rather than the side, to improve the line of sight. Nothing made a difference.
Hersh
Postby Hersh » Sun Jun 22, 2014 12:38 am
So, there's no one to help?
Hersh
