Two version of MOI Pro will coming soon
Postby steven » Fri Jun 13, 2014 11:47 am
HI All
Two version of MOI Pro will coming soon.
The first one is using
CPU Marvell 88F6282 1.6 GHz (can be updated to 2.0 GHz)
RAM 1GB DDR3 flash
Ethernet 1x /100/1000M Gigabit Ethernet LAN
One PCI-E slot with lots of TBS PCI-E card support (DVB-S DVB-T DVB-C),you can use the one you wan,such as TBS6985 or TBS6991 and so on...
Here is the picture with TBS6991:
With TBS6991
Another one is using
CPU Freescale imx6q quad core 1.0GHz
RAM 2GB DDR3 flash
Two PCI-E slot with lots of TBS PCI-E card support (DVB-S DVB-T DVB-C),you can use the one you wan,such as TBS6985 or TBS6991 and so on...
Here is the picture with TBS6985:
Any advice about these two product will be appreciated. :)
Re: Two version of MOI Pro will coming soon
Postby hetnet » Thu Jun 26, 2014 2:49 pm
Will the MOI PRO II have support for "SAT>IP" protocol?
hetnet
Return to MOI Pro DVB-S2 IP Streamer
