Decoding VP8/Vorbis problem
Postby laurentfal » Thu Jun 05, 2014 7:07 pm
I got my TBS2910 just a couple of days before.
Everything is working like a charm, except for decoding videos in vp8 (audio : vorbis).
The video works for a couple of seconds (40-50s) and then it begins to be jerky, with the audio going on and off.
The fps decreases and becomes variable. CPUs are all below 5% most of the time.
All others videos (h264 for example) are OK.
Those videos come from Youtube, I have tried with at least 4 or 5 videos from this type and this is always the same problem.
Thinking that it was maybe the Youtube plugin, I downloaded one of those video and put it on the local drive : Same result.
Youtube videos that are not in vp8 work without any problem.
Do you already have experienced such a problem ? Is this a bug ? a configuration problem ?
I'm running the Matrix-TV V1.0.0.7, Audio SPDIF/Passthrough
Thank you for your help.
laurentfal
Re: Decoding VP8/Vorbis problem
Postby Cjcr » Fri Jun 06, 2014 4:22 am
Yes, is a bug and is know for the developers of XBMC for IMX.6.
Is still unfixed.
Cjcr
Postby laurentfal » Fri Jun 06, 2014 3:29 pm
Ok, many thanks four your answer.
Let's hope that they will find a fix.
laurentfal
Return to General discussion
