TBS MatrixTV system update to V1.0.0.6-1
Postby steven » Mon Apr 28, 2014 9:17 am
Hi all
TBS MatrixTV system has been updated to V1.0.0.6-1 with following improvements:
1.Fix can not use the HDMI-CEC problem.
2.Update to wolfgar's laetst XBMC version.
3.Fix can not use the Power off ,Reboot and Exit button with XBMC.
4.Add multy boot target choose,VDR or TVheadend.
5.Default remote suppport for TBS NEC32 remote.
6.Fix some small bugs.
Here is the download link:
http://sourceforge.net/projects/matrixt ... p/download
In this package already include the DVB-T and DVB-C kernel,In burn tool Profiles\MX6Q Linux Update\OS Firmware\files folder. :)
If you want to use the DVB-T just rename the uImage_DVBT_20140426 file to uImage.
or DVB-C uImage_DVBC_20140426 to uImage
Any feedback will be welcome. :)
Re: TBS MatrixTV system update to V1.0.0.6-1
Postby alanb2121 » Tue Apr 29, 2014 4:53 pm
Thanks Steven, looks good. remote works well :)
First issue I have come across is when doing a VDR channel scan it seems to do nothing, drops back to the main menu almost immediately
alanb2121
Postby alanb2121 » Tue Apr 29, 2014 6:39 pm
Another bug that was present on the last build but I don't recall being there before that. When selecting 5.1 sound the channels are mixed up. I.e Center channel is coming out of surround left. Is there a file somewhere that I can edit to correct this?
This only occurs when the output is PCM. DD and DTS with pass through work fine
alanb2121
Postby steven » Tue Apr 29, 2014 6:39 pm
alanb2121 Wrote:Thanks Steven, looks good. remote works well :)
Hi alanb2121
Really thanks for your feedback. : )
can you give us more detail information,such as which tuner you are using and what is your DiSEqc setting?
Kind regards
Postby sepinho » Tue Apr 29, 2014 8:01 pm
Will this overwrite my current 1.0.0.5 installation or can I update and keep my current settings?
sepinho
Postby Cjcr » Tue Apr 29, 2014 10:31 pm
There's no way to turn on the Matrix device if you power off it from XBMC's menu. The only way is just restart. Power on/off button doesn't work. :cry:
Cjcr
Postby mijanek » Wed Apr 30, 2014 12:54 am
Hi Steven,
nice build. Thanks, for me is everything working fine, SD, HD as well as USB-DVD works well :-)
mijanek
Postby alanb2121 » Wed Apr 30, 2014 4:46 am
Hi alanb2121
Kind regards
I'm using the TBS 5922. I don't use a DiSEqc. I've tried various settings and get the same result.
alanb2121
Postby steven » Wed Apr 30, 2014 10:01 am
sepinho Wrote:Will this overwrite my current 1.0.0.5 installation or can I update and keep my current settings?
Hi sepinho
for the backup maybe you can have a look at this topic.
viewtopic.php?f=156&t=8807&p=30453&hilit=xbmc+backup#p30453
It will help you how to ,later we will add the online update for our MatrixTV's application. :)
Postby steven » Wed Apr 30, 2014 10:03 am
Cjcr Wrote:There's no way to turn on the Matrix device if you power off it from XBMC's menu. The only way is just restart. Power on/off button doesn't work. :cry:
Hi Cjcr
Really sorry that this version of hardware only support power off ,the power on by remote is not supported.
You need to manual power on matrix by yourself.
Power on by remote maybe we will add it in future. :)
Return to Announcements
