Can't Record More Than 2 Channels At The Same Time
Postby timmilstead » Tue Apr 22, 2014 3:37 am
When I try to record more than two channels at the same time in Windows Media Center I get the following error:
-1073478364
If I try and do the same in TBS Viewer the program crashes.
Windows 8.1 64bit.
i7 3770S
32GB RAM
timmilstead
Re: Can't Record More Than 2 Channels At The Same Time
Postby smile » Wed May 07, 2014 10:34 am
hi timmilstead
Do you used the same tuner to record at the same time?
thanks.
smile
Postby quartermain » Wed May 14, 2014 2:14 am
I had something very similar. With Win7 and the 1.0.0.6 drivers I could only get tuners 1 and 2 to record - 3 and 4 would not. Downgrading to the 1.0.0.5 drivers fixed it.
However the 1.0.0.6 drivers work OK on Win8.1.
quartermain
