TB5922 Stopped working
Postby amasidlover » Tue Apr 15, 2014 3:58 am
I've had a TBS5922 working for the last 3 weeks. I initially got it working with scan-s2 included with the drivers and then mythtv - however a couple of days ago Mythtv stopped part way through a recording and stopped being able to tune with the TBS9522 and the logs said 'Invalid Argument'.
Now when I try scan-s2 I get:
noam scan-s2 # ./scan-s2 -a2 -x0 test.scan
API major 5, minor 3
scanning test.scan
using '/dev/dvb/adapter2/frontend0' and '/dev/dvb/adapter2/demux0'
initial transponder DVB-S  10714000 H 22000000 5/6 35 QPSK
initial transponder DVB-S2 10847000 V 23000000 8/9 35 QPSK
>>> tune to: 10714:hC56M2O35S0:S0.0W:22000:
DVB-S IF freq is 964000
FE_SET_PROPERTY TUNE failed: Invalid argument
----------------------------------> Using DVB-S2
>>> tune to: 10847:vC89M2O35S1:S0.0W:23000:
DVB-S IF freq is 1097000
ERROR: initial tuning failed
dumping lists (0 services)
Done.
I've tried powering off the unit and re-connecting it and also rebooting the mythtv backend it is connected to. The box appears to load OK according to dmesg.
[74248.830371] usb 1-2.2: new high-speed USB device number 10 using ehci_hcd
[74248.940873] usb 1-2.2: New USB device found, idVendor=734c, idProduct=5922
[74248.940881] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[74248.940886] usb 1-2.2: Product: TBS 5922
[74248.940889] usb 1-2.2: Manufacturer: TBS-Tech
[74248.941345] dvb-usb: found a 'TBS QBOX22 DVBS2 USB2.0' in cold state, will try to load a firmware
[74248.941355] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5922.fw'
[74248.941358] tbsqbox22: start downloading TBSQBOX firmware
[74249.060156] dvb-usb: found a 'TBS QBOX22 DVBS2 USB2.0' in warm state.
[74249.060226] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[74249.060397] DVB: registering new adapter (TBS QBOX22 DVBS2 USB2.0)
[74249.157738] dvb-usb: MAC address: 00:22:ab:c0:2f:33
[74249.460117] TurboSight TBS 5922 Frontend Attaching...
[74249.551879] QBOX22: TBS5922FE attached.
[74249.552255] DVB: registering adapter 0 frontend 0 (TurboSight TBS 5922 DVBS/S2 frontend)...
[74249.552742] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.7/usb1/1-2/1-2.2/input/input11
[74249.552837] dvb-usb: schedule remote query interval to 150 msecs.
[74249.552844] dvb-usb: TBS QBOX22 DVBS2 USB2.0 successfully initialized and connected.
But clearly something is going wrong. Any help would be appreciated...
amasidlover
