turbo modulation
turbo modulation
Postby SunChero » Fri Apr 04, 2014 9:37 pm
guys
could someone shed light on weither TBS products support turbo modulation with 8psk ?
if yes .. please let us know how to activate this in driver
im using TBS8922 PCI
thank you
SunChero
Re: turbo modulation
Postby updatelee » Fri Apr 04, 2014 10:09 pm
None do. The Skywalker-1/2 is what you'd want for that.
Postby SunChero » Fri Apr 04, 2014 10:57 pm
thats really very upseting :S
i do have a jynxbox setop box with a JB200 module which support this modulation .. ths problem is .. i dont know what kind of connector should i use to plug it to my HTPC
its a 20pin connector .. but have no idea what kind of port/connector it needs
http://www.amazon.com/JynxBox-JB200-Sat ... B00BURIXUQ
now that i have wated my money on a TBS card .. i dont wana paye for another one !
do you have any idea on what kind of connector could i use to plug a JB 200 to PC ?
thank you
SunChero
Postby updatelee » Sat Apr 05, 2014 12:34 am
Trust me, you'll want a skywalker-1/2
dont waste your time/money with anything else. Its the only one that really supported.
Even if you managed to make some funky connector and built a usb interface for it, you'd still need to write drivers.
Postby SunChero » Sat Apr 05, 2014 12:45 am
a skywalker card cost 180$ ... on the other hand .. this JB200 which does the same think .. cost 20$
SunChero
Postby updatelee » Sat Apr 05, 2014 3:44 am
your welcome to write a driver for the $20 card.
I own a skywalker-1 and is an excellent card, genpix offers exceptional support. You buy the $20 card and you'll get zero support. You'll be 100% on your own. Do you have experience writing Linux drivers? your welcome to give it a shot, there is lots of educated people out there that could help. But having datasheets helps allot.
The cypress FX2 is a well used usb interface IC, well documented and supported in linux, you'll need to write firmware for it (8051 processor) but there is lots of information on it too. Ive done a little reverse engineering products and I can tell you a very good oscilloscope and logic analyzer helps a ton !
Its a huge job either way.
Postby cilindro » Fri Jul 03, 2015 3:42 am
Any other option than skywalker. Ginpex discontinued all cards and dont sell any more
cilindro
Postby updatelee » Fri Jul 03, 2015 11:57 am
Nope, nothing else
