Freezing issue
Freezing issue
Postby gr4z » Tue Aug 02, 2011 3:57 am
My 6981 is constantly freezing my MCE box when stopping a recording. I assume this is down lack of power for the card? The power adapter shipped with the card has 3 inputs. Are all of these needed? I don't have 3 power connectors available only 1 as the others are all in use!! Why so many?
gr4z
Re: Freezing issue
Postby steven » Tue Aug 02, 2011 3:24 pm
Hi gr4z
do you have transedit?and if you have would you mind have a test ,if transedit have miss pack too,maybe the signal is not very well,
and if it have not miss pack,maybe have some wrong with MCE.
Re: Freezing issue
Postby gr4z » Tue Aug 02, 2011 6:08 pm
My previous card was fine - it was a Pinnacle. That picked up everything in HD on MCE.
It seems the drivers are not very good for DVB-S2 for the UK. Everytime I playback a recording or TV from a HD feed and press STOP my MCE box hangs.
gr4z
Re: Freezing issue
Postby gr4z » Wed Aug 03, 2011 11:20 pm
I still am getting random freezing problems. My PSU is rated at 430W is this enough?
If not I will be sending my card back to Amazon for a refund as I am not prepared to upgrade other components just to get a video card working. My previous Pinnacle worked fine but only does DVB-S not S2.
gr4z
Re: Freezing issue
Postby steven » Thu Aug 04, 2011 9:29 am
Hi gr4z
I want to know ,do you have miss pack on other player, beside MCE,
do you have used DVBDream to have a test ?
Re: Freezing issue
Postby gr4z » Thu Aug 04, 2011 2:52 pm
Dvbdream is not freeware. Can you suggest another free program to test the card with?
*EDIT* I have now rebuilt my MCE box from scratch. Using a DVB-S2 feed I can watch the channel but after about 20 mins if I press STOP the system hangs. Every time.
This is a hardware or software issue with your card as this has never happened before with all my previous DVB-T and DVB-S cards.
gr4z
Re: Freezing issue
Postby steven » Fri Aug 05, 2011 9:31 am
We have OEM DVBDream which is free .
here is the linker:
http://www.tbsdtv.com/download/common/d ... 5g_oem.rar
You can have a try.
