External USB harddisk question
Postby Dippo » Sat Mar 29, 2014 10:18 pm
Hi everyone,
Just got my new Matrix mini PC delivered yesterday and I am extremely happy with it - my old WDTV has taken a short trip straight to the bin !!
One question I would like to ask though - the 2 external USB drives I have connected seem to be spinning all the time even when I am not accessing anything on them. Is there a setting I can change to make them idle when not in use (I'm using the MatrixTV image V1.0.0.5) ? I'm afraid I am pretty linux illiterate so please try and keep any answers simple...
Thanks for a great box & any help you can give.
Dippo
Re: External USB harddisk question
Postby mijanek » Mon Mar 31, 2014 7:45 pm
Just grab and install the hdparm tool from here: viewtopic.php?f=158&t=8892#p30797 and try to ste the proper PME times..
e.g. (You have to adjust the proper device)
hdparm -S 120 /dev/sd[bcd]
mijanek
Postby Dippo » Mon Mar 31, 2014 9:35 pm
Thanks for your help mijanek, I'll give it a try....
Dippo
Postby Dippo » Mon Mar 31, 2014 11:30 pm
Erm sorry mijanek, I did say I was a bit of a Linux dunce !
The program installed OK but when I try to configure it I get :
[root@matrixtv /]# hdparm -S 120 /dev/sda
/dev/sda:
setting standby to 120 (10 minutes)
HDIO_DRIVE_CMD(setidle) failed: Invalid argument
[root@matrixtv /]# hdparm -S 120 /dev/sda1 (wasn't sure if I had to add the '1' but this is how it's shown in /media)
/dev/sda1:
[root@matrixtv /]# hdparm -S 120 /dev/sdb
/dev/sdb:
[root@matrixtv /]# hdparm -S 120 /dev/sdb1
/dev/sdb1:
[root@matrixtv /]#
Any idea what the invalid arguement is or how I can find out ?
Thanks again !!
PS - they are both 2Tb WD Elements USB drives (in case this makes any differance)
Dippo
Postby Dippo » Mon Mar 31, 2014 11:45 pm
Just found this on a Linux site :
DESCRIPTION
hdparm provides a command line interface to various kernel interfaces
supported by the Linux SATA/PATA/SAS "libata" subsystem and the older
IDE driver subsystem. Many newer (2008 and later) USB drive enclosures
now also support "SAT" (SCSI-ATA Command Translation) and therefore may
also work with hdparm. Eg. recent WD "Passport" models and recent
NexStar-3 enclosures. Some options may work correctly only with the
latest kernels.
So maybe it will just not work with my USB drives.....
Dippo
Postby Dippo » Tue Apr 01, 2014 1:38 am
Update, left XMBC running, went to the supermarket and when I got back both disks were idling.
So either hpdarm worked despite the error message or the drives go into idle after some period anyway....
Bottom line is that they're not going to be spinning all night so I'm a happy chappy.
Dippo
Return to General discussion
