TBS Matrix System update...
Postby steven » Wed Mar 26, 2014 3:13 pm
Hi all
TBS Matrix's three system all updated to the latest version. :)
MatrixTV V1.0.0.5:
http://sourceforge.net/projects/matrixt ... p/download
News:
1.Update to wolfgar's laetst XBMC version
2.Add VPU support for MPEG1
3.Fix when watching SD channels(which are deinterlaced) and browsing XBMC GUI,the video become unsmooth issue.
4.Add TBS5922SE Box Tuner support
5.Add USB DVB ROM support
6.Change Fan monitor temperature to 75 degreen,Reduce the fan noise.
7.Update to latest scan-s2 fixed some channel can not play by VDR.
Android V3:
News:
1.Add Fan control in Android,Reduce the fan noise.
2.Add Google play APP store
Ubuntu 11.10_V2:
News:
1.Add Fan control in Ubuntu,Reduce the fan noise.
2.Add the same tuner support as MatrixTV
3.Add OpenVPN support
Any feedback will be welcome. :)
Bouton power ne marche pas.xbmc ça reste bloqué sur éteindre
Postby amine2014 » Wed Mar 26, 2014 5:35 pm
Bonjour steven et communauté Matrix. Help!
Je viens de recevoir mon matrix et le bouton power ne marche pas, et quand je veux arrêter xbmc ça reste bloqué sur éteindre, c'est un bug. :cry:
Merci
Cordialement,
amine2014
Re: TBS Matrix System update...
Postby maxi1978 » Thu Mar 27, 2014 12:32 am
hi steven
thanks for update and all your hard work, i was wondering if the power on/off works on this version of matrix tv?
cheers :D
maxi1978
I just received my matrix and the power button does market
Postby amine2014 » Thu Mar 27, 2014 3:07 am
Hello Matrix community. Help!
I just received my matrix and the power button does not work, and when I want to stop xbmc it stuck on off, it's a bug. : cry:
thank you
Regards,
amine2014
Postby NightMare » Thu Mar 27, 2014 5:43 am
What is the ssh logins :?
NightMare
Re: Bouton power ne marche pas.xbmc ça reste bloqué sur étei
Postby winterfell » Thu Mar 27, 2014 11:08 am
amine2014 Wrote:Bonjour steven et communauté Matrix. Help!
Merci
Cordialement,
Bonjour, nous sommes en train de trouver solution pour résoudre ce problème , merci de faire attention aux nouvelles dans notre website et notre forum :D
winterfell
Postby amine2014 » Thu Mar 27, 2014 10:12 pm
Bonjour Matrix ARM community
ok merci,comment je peux l'éteindre avec ce problème?
Cordialement
amine2014
Postby jowski » Sun Mar 30, 2014 4:22 am
NightMare Wrote:What is the ssh logins :?
root/root
Jim
jowski
Return to Announcements
