Mini PC bootloop on Android
Postby ghardashyan » Tue Mar 18, 2014 5:28 pm
TBS2910 hangs on boot with an "Android" logo animation after flashing the Android image. However XBMC boots fine. Even more: after flashing the V2 Android image from the Debug directory ( from MatrixTV sourceforge ) the device works, a bit laggy though but it boots. I've tried to flash the 4.2.2 Release image multiple times but it simply doesn't boot. Any suggestions what's wrong are highly appreciated.
Best regards.
ghardashyan
Re: Mini PC bootloop on Android
Postby gowain » Wed Mar 19, 2014 12:15 am
I have the same problem - 3 times I tried to burn Android firmware and always the same - stuck on Android logo.
gowain
Postby steven » Wed Mar 19, 2014 4:13 pm
Hi All
Please have a try using our latest Android which fixed this problem.
http://sourceforge.net/projects/matrixt ... p/download
Postby ghardashyan » Wed Mar 19, 2014 8:50 pm
steven Wrote:Hi All
Thanks ( had a no chance to try it, though ).
ghardashyan
Postby gowain » Thu Mar 20, 2014 12:58 am
steven Wrote:Please have a try using our latest Android which fixed this problem.
After burn it works, slow, but works. But after first reboot same problem that previous - stuck on Android logo :(
gowain
Postby steven » Thu Mar 20, 2014 4:07 pm
Hi gowain
Do you mean ,it only works the first time after you burn the new system??
Can you restart the Matrix some times ,if the problem always happen,maybe
other problem affect this.
In a short we will have more check with this problem.
and will release a solution . Please do not worry about this.
Postby gowain » Thu Mar 20, 2014 5:12 pm
Yes, it only works for the first time after burn Android firmware. If I turn off or restart device it stuck on Android logo. I will try to burn it again. Thanks for fast reply - I hope it will be ok :)
gowain
Return to General discussion
