How to set a different outut resolution (XBMC)
Postby Sat4all » Mon Feb 24, 2014 7:50 pm
Settings the video output resolution from XBMC is blocked somehow. It seems to be fixed at 1080p@60Hz.
I would like to use 720p@50Hz or 1080i@50Hz. How can I get this done?
Kind regards,
Michel
Sat4all
Re: How to set a different outut resolution (XBMC)
Postby mijanek » Tue Feb 25, 2014 4:58 am
You may try this from the console. (taken from Koying@xbmc forum)
check supportet resolutions..
cat /sys/class/graphics/fb0/modes
and dynamically change it with, e.g.
echo 1 > /sys/class/graphics/fb0/blank
echo U:1280x720p-60 > /sys/class/graphics/fb0/mode
echo 0 > /sys/class/graphics/fb0/blank
mijanek
Postby Sat4all » Tue Feb 25, 2014 5:15 am
Have you actually tried this?
Sat4all
Postby mijanek » Wed Feb 26, 2014 1:54 pm
No, as I didn't need this, but others yes. Isn't it working?
mijanek
Postby bzoli72 » Thu Feb 27, 2014 2:00 am
mijanek Wrote:You may try this from the console. (taken from Koying@xbmc forum)
Hi mijanek!
With matrixTV 1.0.0.3-1 version:
[root@matrixtv ~]# cat /sys/class/graphics/fb0/modes
S:640x480p-60
S:1920x1080p-30
S:1920x1080p-25
S:1920x1080p-24
S:720x576p-50
S:720x480p-60
S:720x480p-60
S:1280x720p-50
S:1280x720p-60
S:1920x1080p-50
S:1920x1080p-60
V:640x480p-60
D:1920x1080p-60
V:640x480p-60
echo S:1280x720p-60 > /sys/class/graphics/fb0/mode is working.
bzoli72
Postby Sat4all » Thu Feb 27, 2014 2:58 am
Looked everywhere, read all documentation, but no root password or other shell login credentials to be found :(
maybe documentation could be updated... No one guesses the root password to be root ;)
What is the exact syntax to set it to 720p@50Hz?
Tried several options, but get nothing but errors...
Sat4all
Postby Cjcr » Thu Feb 27, 2014 3:14 am
Sat4all Wrote:What is the exact syntax to set it to 720p@50Hz?
Should be:
echo S:1280x720p-50 > /sys/class/graphics/fb0/mode
Cjcr
Postby Sat4all » Thu Feb 27, 2014 3:21 am
Thanks, 1920x1080@24Hz works. Picture is not very nice, but at least I am having some picture.
Sat4all
Return to General discussion
