6925 & windows 8.1
6925 & windows 8.1
Postby dogman » Fri Feb 21, 2014 8:40 am
Is the 6925 compatible with windows 8.1 64 bit?
Reason I ask is that it does work but the card frequently stops working (cannot be detected) and I have to physically remove the card from the computer and then replace it. the card will then work normally until the next time.
Any explanation why?
dogman
Re: 6925 & windows 8.1
Postby dogman » Fri Feb 21, 2014 7:47 pm
I have been told by a number of people that they are aware of a problem with TBS 6925 V2.23 cards and some motherboards.
Any truth in this?
My motherboard is an ABIT IP35 Pro XE.
My card works normally for a few weeks then begins to struggle and I always have to remove and replace the card and it will work normally for a few weeks again until the next time.
Very annoying.
dogman
Postby dogman » Fri Feb 28, 2014 7:41 am
Exactly the same thing has happened tonight.
So what is the problem with this card?
I am beginning to regret ever purchasing it.
No response from a TBS rep yet!
dogman
Postby dogman » Sat Mar 01, 2014 1:25 am
No response? :(
dogman
Postby dogman » Sun Mar 09, 2014 10:28 pm
Still no response???????
Is there any support anymore?
I am having to uninstall my 6925 card frequently including the driver and then reinstall or the card does not function correctly.
I ask again, Is there a known problem with Revision v2.3 cards and some motherboards?
I have been told there is by someone who had a similar problem and the answer was to replace the card with a different revision card.
dog-man...
dogman
Postby dogman » Fri Mar 21, 2014 10:50 pm
I have now noticed that when scanning with my 6925 I get a different FEC to what my receivers get.
Does this give a clue as to what my problem is?
I am still waiting for a reply from admin / support.
Is TBS now dead?
At the moment it is extremely unlikely that I will be purchasing another TBS product in the future or recommending anyone to buy one. Sad, because when it works properly it is excellent.
dog-man...
dogman
Postby starman345 » Sat Mar 22, 2014 9:26 am
I have a 6925 and run it with Windows 8.1 64 bit. No problems that I've noticed. I don't know what version the card is, I bought it a couple of years ago. Have you tried playing with the pci-e settings in your motherboard bios? On my Asus mb the modes can be changed. I've read those settings can affect some cards but have no evidence personally, something to try.
10' dish- Bullseye II c/ku
55.5W to 139W
Windows 8.1 64 bit
TBS 8922 Prof 7301 TBS 6925
starman345
Postby dogman » Sat Mar 22, 2014 6:53 pm
I did have a look in the bios and it seems that the only changes I can make that would affect the pcie slot is to set it to either v1.0 or v1.0a.
I think it is currently on v1.0.
Is there any other setting I could alter?
Thanks for replying. It's a pity support don't bother to reply anymore. This card was not cheap, but they have lost a customer.
By the way, the card version is printed on the card. I have v2.3 which apparently has a problem with some motherboards.
dog-man...
dogman
Postby starman345 » Sat Mar 22, 2014 9:29 pm
I pulled the 6925 card and it is a 2.3 version. My pci-e bios options are x1 x4 or auto, it was set to auto on install so I just left it, it seems to work okay there. Not sure what else to tell you, the mb is an Asus P8 Z77-V Pro. I'm using the 1.0.1.20 driver for 64 bit.
55.5W to 139W
Windows 8.1 64 bit
starman345
Postby dogman » Sat Mar 22, 2014 9:37 pm
I am using the newer driver for 64 bit. V1.21.
I will downgrade to v1.20 and give that a go, but I am fairly sure I had the same problem with that driver also.
I will also have another look in my bios.
dog-man...
dogman
