TBS8922 has signal but no channels tuned
Postby Dreaming » Mon Feb 17, 2014 7:35 pm
I am having an identical issue to this person here:
viewtopic.php?f=11&t=8149
but with the TBS8922 card.
I have tried to replicate his steps for a solution in deleting the drivers from windows itself, but have so far not been able to get success.
I am getting a signal strength of around 95% in TBS blindscan.
Using Windows Media Centre, and then DVBdream I again have found no channels.
Running Windows 8.1 Professional x64 with Windows Media Centre, with an Asus P8H77-M motherboard.
This is my first foray into satellite on a PC so maybe I have set something up incorrectly.
Dreaming
Re: TBS8922 has signal but no channels tuned
Postby Dreaming » Mon Feb 17, 2014 11:14 pm
Spoke to support who said:
"so, it seems to me that 8922 card is faulty - tuner signal path and digital data path are separate - if the tuner can lock, but cannot receive data, that suggest some fault in the digital data path on the board."
So it might just be a return and replace job?
Dreaming
