MatrixTV beta version V1.0.0.3
Postby steven » Mon Feb 10, 2014 5:17 pm
Hi All
MatrixTV beta version V1.0.0.3 is already released. if you want to have a try you can get it here.
http://sourceforge.net/projects/matrixtv/files/Debug/TBS-MatrixTV-V1.0.0.3_Debug.zip/download
have the following update:
1.Use wolfgar latest XBMC which fixed a lot of problem especially about the HD .Thanks very much for the effort made by wolfgar. :)
2.Add TBS USB tuner support for the following products:
TBS 5990 Dual DVB-S/S2 CI BOX
TBS 5280 DVB-T/C
TBS 5281 DVB-T/C
3.Merge wolfgar latest kernel update.
4.Fixe some small bugs.
The latest code has already uploaded to SF too. This version will be more stable than the previous one :)
Any feedback will be appreciated.
Re: MatrixTV beta version V1.0.0.3
Postby bzoli72 » Tue Feb 11, 2014 3:46 am
Hi Steven!
TBS5925 not working with MatrixTV beta 1.0.0.3.
DiSEqC settings = No DiSEqC
LNB settings : 9750/10600 Ku Linear
Scanning results:
>>> Tune to: 10778:HC78M2:S1.0W:24500:
DiSEqC: uncommitted switch pos 0
DiSEqC: switch pos 0, 18V, hiband (index 3)
DVB-S IF freq is 1028000
>>> tuning status == 0x00
WARNING: >>> tuning failed!!!
This is the all frequencies.
bzoli72
bzoli72
Postby matchboxx » Tue Feb 11, 2014 4:47 am
scan 4 sats - 120´, thor impossible is not 1°W but 0,8°W
matchboxx
Postby bzoli72 » Tue Feb 11, 2014 5:19 am
I create in /root//usr/share/transponders folder S1.0W.ini file from S0.8W.ini file.
bzoli72
Postby steven » Tue Feb 11, 2014 9:10 am
bzoli72 Wrote:Hi Steven!
Scanning results:
bzoli72
Hi bzoli72
Before release this beta version, i have already tested TBS5925 with Matrix by myself,which is ok.
So can you have a try test it in Windows,make sure that your TBS5925 is ok.
Postby matchboxx » Tue Feb 11, 2014 5:28 pm
bzoli72 Wrote:I create in /root//usr/share/transponders folder S1.0W.ini file from S0.8W.ini file.
i will try it today later :D
matchboxx
Postby bzoli72 » Wed Feb 12, 2014 1:11 am
Hi bzoli72
Hi steven!
I tested my TBS5925 in Win7 and work perfectly.
With MatrixTV not working.
bzoli72
bzoli72
Postby matchboxx » Wed Feb 12, 2014 11:25 pm
tested, work, thanks :D
matchboxx
Postby bzoli72 » Thu Feb 13, 2014 1:08 am
Hi steven!
I testing the software in 2 different TBSMatrix hadware with 2 different tuner. (TBS5925 and TBS5922)
Testing results:
TBSMatrix 1 + TBS5925 --> Tuning failed from MatrixTV config menu
TBSMatrix 1 + TBS5922 --> Tuning failed from MatrixTV config menu
TBSMatrix 2 + TBS5925 --> Tuning failed from MatrixTV config menu
TBSMatrix 2 + TBS5922 --> Tuning failed from MatrixTV config menu
So hardware or software problem?
bzoli72
bzoli72
Postby Cjcr » Thu Feb 13, 2014 1:15 am
I bet that is a w_scan or szap problem ... I have the same problem here with 1.0.0.3 but it works well if preload the channels.conf file from a backup and run it with VDR+XBMC
Cjcr
Return to Announcements
Users browsing this forum: Google [Bot] and 7 guests
