Important questions
Important questions
Postby Xonosom » Sun Jan 26, 2014 10:06 pm
1. Is it possible to use MOI with DVBVewer?
2. Is it possible to record tv shows on SD card or USB pendrive connected to MOI without using any external devices?
regards
Xonosom
Re: Important questions
Postby babboy » Mon Jan 27, 2014 5:38 am
Hello
1. Is it possible to use MOI with DVBViewer?
No
yes i use it with Tvheadend ;-)
Mfg babboy
babboy
Return to General discussion
