drivers on windows vista 32 bit
Postby daveash » Wed Sep 08, 2010 11:20 pm
i have installed drivers but it also lists QBOXS2 VHID Device and will not install drivers for this were can i find 32bit drivers
daveash
Re: drivers on windows vista 32 bit
Postby cody » Thu Sep 09, 2010 4:20 pm
you need to install VHID driver as you install any other driver in Windows, it's located on the installation CD or if you use drivers downloaded from the website in the same folder as where you extracted the driver archive. or maybe, i don't understand the problem you're experiencing correctly?
