where to get a rs232 adapter
Postby celevra » Wed Jan 08, 2014 3:26 pm
i have to update the moi from 1.x to 2.x an i need a rs232 adapter because as it seems it is not an standard rs232 plug at the moi.
Where can i get this adapter?
Best regards
celevra
celevra
Re: where to get a rs232 adapter
Postby wankel » Mon Jan 13, 2014 4:56 pm
Sorry, no answer, but a question in the same direction:
What is the order of the pins on the back? The connector looks like a floppy disk power connector, is it that?
I saw the picture of the "normal" serial cable on viewtopic.php?f=92&t=8691&p=30101&hilit=rs232#p30101, but not with the MOI-connector.
Thanks!
wankel
Postby franzp » Fri Mar 28, 2014 9:21 pm
The adapter was delivered with my MOI Box, but even if you have the Adapter.. The Update via this Serial Cable is a shame.
franzp
Return to General discussion
