Only receiving HD channels(Solved)
Postby quin » Mon Jan 06, 2014 4:39 am
Almost up and running with a tbs 6220 using windows 8.1 but I can only get HD channels (6 of them) but digital/terrestrial channels won't open (160 of them). I would appreciate being pointed in the right direction - advancing years being a barrier to logic!
Also, is it possible to delete previous scans from the list in tbs viewer?
... and what does the 'favorites' box do that is useful?
quin
Re: Only receiving HD channels
Postby quin » Thu Jan 09, 2014 5:26 am
All is fine now!
Thanks.
quin
Postby steven » Sat Jan 11, 2014 8:09 pm
thank you very much for your update :)
