TBS 8921 Pci-remote problem
Postby mqover79 » Tue Dec 31, 2013 3:51 pm
I bought a TV card, model tbs 8921 dvb-s s2.
Additionally bought dvb viewer pro. I have the following problem with this program.
I can not run the pilot. There is no plugin to handle remote control DVBViewer.
Sorry for my english. I am writing from Polish.
Please help me. Thank you for any tips.
mqover79
Re: TBS 8921 Pci-remote problem
Postby steven » Sat Jan 11, 2014 8:16 pm
Hi mqover79
Do you have installed the TBS8921VHID ? you can use the VHID to control DVBViewer. :)
After you have success installed the TBS8921VHID ,you can manual config DVBViewer remote option.
