picture brack up
picture brack up
Postby Blaze » Sat Jul 30, 2011 6:47 pm
Hello all I am new to this forum
I have a Q box S2
The picture stays stable for about 30 secounds using DVD Dream and then it bracks up as if the signal is poor, even though the signal is 90 and the quality is 77 I havw medion computer with a 3.00Ghz duel core pentium ,3gb of RAM AND A NVidia Ge force 9400gt with 512mb ram
Windows media player is unable to find channels
Any help is apreciated
blaze
Blaze
Re: picture brack up
Postby steven » Sun Jul 31, 2011 6:17 pm
Hi Blaze
Would you mind try to move your dish to get good signal,or try to use another Video code.
Postby Blaze » Mon Aug 01, 2011 1:21 am
Hello Steven
I have changed the video codes around but still no different. I have another sat receiver a sky star usb 2 hd cI
This will run without problems with the q box software there is no picture break up on SD or HD signals with that unit.
I also have a tv skybox running of a Sky Satellite Dish MK4 Quad LNB which works without problens I don't think the signal is the problem .
I think I have a hardware problem with the Q box s2 unit ,what do you think
Yours
Blaze
Blaze
Postby steven » Tue Aug 02, 2011 3:23 pm
Hi Blaze
Would you mind write an email to our support@tbsdtv.we will give you a solution.
