TBS USB tuners ARM drivers
Postby denhams » Fri Dec 13, 2013 9:43 pm
Does the release of the Matrix Arm Mini imply that open source ARM drivers are available for the TBS USB tuners?
denhams
Re: TBS USB tuners ARM drivers
Postby updatelee » Fri Dec 13, 2013 10:27 pm
Some are open source, some are not. Some have open source drivers outside the tbs tree, some are still closed source only.
Return to General discussion
