how to see multistream channels...
Postby ferrariteam » Tue Dec 03, 2013 1:52 am
hello, I am new in forum,have a tbs 5925 and want to see multistream,acm vcm channels but dont now to work with tbs...pleas a help how to install,who is important to install for see this multistr.acm vcm in hot bir, 12.5w etc ft
ferrariteam
Re: how to see multistream channels...
Postby tbsuser18 » Fri Dec 06, 2013 11:17 am
even i am new and trying to make MIS work but no success yet
hope some users who are using this for long come and update us
tbsuser18
Postby updatelee » Fri Dec 06, 2013 1:52 pm
Have you tried crazyscan ?
Postby ferrariteam » Sun Dec 08, 2013 7:40 pm
Thanks updetelee, for the answer, I'm iri Active and not know how to work tbs shitty, like you and like you around sea :?: rch Multistream channels, ACM, VCM for which I bought the tuner .... please help as begin the search as you memorize and which programs should be installed somewhere tbs ... please help me ... ft
ferrariteam
Postby updatelee » Sun Dec 08, 2013 11:13 pm
I do not use Windows. I only use Linux.
So I do not know Windows applications very well. I am told crazyscan can be used for ACM VCM.
http://sourceforge.net/projects/crazyscan/
I believe you must install both crazycat's drivers and his software.
Postby ferrariteam » Tue Dec 10, 2013 3:49 am
updatelee friend, sorry to inconvenience you are, but is the last time ... Ihave :?: downloaded crezyscan ... the problem now is how do you see the channels, should not use widows media center ... to himself as to what the program looks please help .. for the last time .... ft.
ferrariteam
Postby updatelee » Tue Dec 10, 2013 5:28 am
I use vlc in Linux for streaming video.
