Adding a 6280 to an existing 6981 setup
Postby rbel » Sun Dec 01, 2013 10:10 pm
I have an HTPC running a 6981 satellite card controlled by a Hama/Gmyle MCE remote and using WMC. I am thinking of adding a Freeview 6280 card to provide greater flexibility. I cannot work out how the one Hama/Gmyle remote could control both cards and would rather not have yet another remote. I did try a One For All URC 7960 universal remote a while ago but could not even get it to recognise the 6981.
Grateful for any suggestions.
rbel
Re: Adding a 6280 to an existing 6981 setup
Postby updatelee » Mon Dec 02, 2013 2:07 am
The remote doesn't control the card, it controls the user software. It's up to the software how it uses the second card
Postby rbel » Tue Dec 03, 2013 4:14 am
Thanks for the response - I will take my question to the WMC forum.
rbel
