Unable to connect via serial
Postby bimse » Sat Nov 30, 2013 4:51 am
Even following the instructions I am unable to connect via Serial nothing happens what so ever. Please help.
bimse
Re: Unable to connect via serial
Postby SergioDanielG » Sat Nov 30, 2013 8:53 pm
Hi bimse.
Can you tell me which software are you using to connetc to MOI?
Have you got serial connector on your pc or are you using some adapter usb-serial?
Did you test your serial cable? Is it a really full modem cable?
Regards.
SergioDanielG
Postby bimse » Sat Nov 30, 2013 9:50 pm
Hi Sergio,
Thanks for your reply. I have so far tried on 2 computers, one with a usb to serial adapter, the other one with a real serial port. On both computers I have tried with 3 different cables: 2 different null modem cables and 1 normal serial cable. I have also tried changing the com port number, nothing seems to work. Software I have tried so far is Tera Term and Putty (both on windows 8).
bimse
Postby franzp » Fri Mar 28, 2014 9:12 pm
i have the same Problem:
- TerraTerm on internal serial Port or on USB to Serial Port with different cables. No Connection possible. With SSH on the IP Adress after Booting the device works.
Is there a way to prepare the Box, to use the new BIN File at next Boot?
thx.
Franz
franzp
Return to Install and setup
