TBS6984 remote lirc.conf
Postby ceesquared » Wed Oct 30, 2013 11:36 pm
Ref: tbs6984 ir remote under LINUX. I've tried the web, I've tried irrecord but with no success. The ir receiver works with another remote and I have a lirc.conf for that remote. However I try, I cannot get the boxed ir remote to work. With irrecord it will find a RC-5 remote but when I try to input keys i get no response. Using irrecord in force raw mode give a file but it does not work! Has anyone got a working lirc.conf file for a TBS remote 2012 vintage boxed with TBS6984. As an after thought, could TBS supply a lirc.conf for the remote as standard. Would TBS give the source of the remote so I could search for other than TBS ( e.g. is it a re-badged Phillips?)
ceesquared
Re: TBS6984 remote lirc.conf
Postby SergioDanielG » Thu Oct 31, 2013 6:50 am
Hi ceesquared.
I never use lirc with tbs cards. Remote it's detected as an input device and, for example, to use remote with vdr, I use
cat /proc/bus/input/devices
to see imput device number.
Hope it's util for you.
Regards.
SergioDanielG
Postby ceesquared » Thu Oct 31, 2013 5:21 pm
Thanks Sergio, but I need to use irexec so I must use lirc. I am using a One for All which is "too complicated" for other users and I am trying to use the TBS as a second remote for Mythtv.
ceesquared
Postby SergioDanielG » Thu Oct 31, 2013 9:01 pm
I don't remember how, but I used remote control with mythtv...
Give me some time to remember.
SergioDanielG
Postby crazycat » Fri Nov 01, 2013 4:26 am
RC work like devinput device. So you must configure lirc work with devinput device or just install simple replacement inputlirc (act as lirc server for devinput devices).
Postby ceesquared » Fri Nov 01, 2013 5:18 pm
Thanks crazycat. The receiver is working OK and I am using a different remote with a suitable lircd.conf. I want to use two different remotes.
ceesquared
