Windows 8.1
Windows 8.1
Postby derres » Fri Oct 18, 2013 8:50 pm
Hi all,
I recently updated to Windows 8.1 Pro today. Now neither DVBViewer 5.2.8.0 nor Transedit 3.9.4.0 can tune to a channel. Even a deinstallation of the driver/card didn't change a thing. I'm running driver version 2.1.6.0. The hardware in device manager don't show any error. The codecs are also correct because the connection to a recording service on an other PC will run well. Any suggestions?
derres
Re: Windows 8.1
Postby derres » Sat Oct 19, 2013 8:41 pm
Found the troubling part ... the tuner A and B are switched. So my configuration with a motor was wrong after the update.
derres
Re: Windows 8.1
Postby Retiree » Sun Oct 20, 2013 8:53 pm
Install the last version DVBV (5.2.8.1)... With installation should fix any errors that may occur when you upgrade to Win 8.1.
Then possibly put another question, the best on a DVBVewer forum
Retiree
