nextpvr not getting signal at all
Postby quick001980 » Tue Sep 24, 2013 10:21 pm
hello. I am trying to set up my tbs6922 with nextpvr. I have echo7 on diseq bb and echo 10 on diseq aa. I get no signal from either. it scans perfectly well with dvbdream but not with nextpvr or mediaportal. What am i missing and tbs please help. it says in your product info that my card would work with nextpvr and mediaportal and it is not working with either. :evil: :evil:
quick001980
Re: nextpvr not getting signal at all
Postby steven » Wed Oct 02, 2013 10:39 pm
For MediaPortal do you have used this patch which added the DiSeqc support?
http://forum.team-mediaportal.com/threa ... ts.103276/
Or you can have a try with this test version:
http://sourceforge.net/projects/mediapo ... p/download
Postby quick001980 » Thu Oct 17, 2013 10:03 am
Figured it out. I had to change all my transponders manually from circular to linear and then it worked. I hope I can help other people with this information.
setup is
mediaportal 1.3final
echostar 7, and 10
quick001980
