[ Moderator Control Panel ]
by Huntress » Fri Sep 20, 2013 6:58 pm
Is TVHeadend loosing all its settings when I update Moi via MMC?
Till there is no button to export/import TVHeadend config, can someone give me a manual for saving the TVHeadend config? (E.g. copy the config file to MMC and back to another MOI)
I´m able to connect via putty, but I´m new with linux and have no idea what I´m actually doing.
Here some ideas for upcoming updates:
A button to export/import TVHeadend config would be nice.
Also an option to add my own NTP Server.
Huntress
by Huntress » Sun Sep 22, 2013 5:12 pm
Also NTFS support for USB and MMC would be nice. Recordings in Matraska are smaller, but max. filesize is limited to 4GB with FAT32.
Edit: What other file systems are supported? Can I format my MMC card directly with the Moi?
Huntress
Return to General discussion
