Card not detected on Ubuntu 13.04 x64 (kernel 3.8)
Postby mrtrigger » Mon Sep 16, 2013 2:11 pm
after upgrading Ubuntu to latest kernel 3.8 the TBS 6981 card isn't recognized at startup. It's listed as a PCI-device (using lspci -nnk) but there is no mention of it in dmesg and /dev/dvb/ isn't created. I'm using the latest drivers from the website build using the following steps.
> sudo make distclean
> sudo ./v4l/tbs-x86_64.sh
> sudo make
> sudo make install
Am I compiling against kernel 3.x? Shouldn't there be a ./v4l/tbs-x86_x64_r3.sh?
Will provide ouput from uname -a, lspci -nnk etc. when I get home, but anyone got any ideas in the meanwhile?
mrtrigger
Re: Card not detected on Ubuntu 13.04 x64 (kernel 3.8)
Postby SergioDanielG » Mon Sep 16, 2013 7:20 pm
Hi mrtrigger.
In my case, when kernel update, I had to delete media tree from kernel modules. /usr/lib/modules/<your kernel version>/media or something like this. But be carefull.
Regards.
SergioDanielG
Postby mrtrigger » Tue Sep 17, 2013 2:18 am
Worked like a charm, thanks SergioDanielG! :D
Just to help others that may be in the same situation, I just ran:
> sudo mv /lib/modules/$(uname -r)/kernel/drivers/media ~/media.bak
> sudo make install
> sudo reboot
After reboot the card was detected as normal.
mrtrigger
Postby updatelee » Tue Sep 17, 2013 3:21 am
This has been mentioned numerous times on the forum, would be nice to see in the readme.
Postby sevy1794 » Fri Oct 18, 2013 3:38 pm
I have to say that I had the same problem, and the procedure of removing kernel/drivers/media (which is very agressive as it removes stuff which is not related to tbs at all) does not work.
I updated to Ubuntu 13.10 and the same problem exists there, even with the latest driver.
Is there any other fix ?
sevy1794
Postby updatelee » Fri Oct 18, 2013 9:18 pm
Post your kernel logs and we cab see what's going on
Postby brettser » Mon Oct 28, 2013 7:01 pm
I had issues with install on 12.04/12.10/13.04 and again with 13.10 - From reading other posts I think the issue is down to file permissions in the zip file plus you need to use "make" instead of "sudo make" (read in post months ago, now dead.)
mkdir driver
cd driver
wget http://www.tbsdtv.com/download/document/common/tbs-linux-drivers_v130927.zip
unzip tbs-linux-drivers_v130927.zip
find -type d -exec chmod 755 {} \;
chmod 755 linux-tbs-drivers/v4l/scripts/*
find linux-tbs-drivers -name “*.sh” -exec chmod 755 {} \;
cd linux-tbs-drivers
sudo make distclean
cd /lib/modules/$(uname -r)/kernel/drivers
sudo mv media /home/yourusername/media.bak
make
sudo make install
sudo shutdown -r now
Worked for me , best of luck!
Gavin
http://linux.mjnet.eu/post/401/tbs-driver-install-ubuntu-11-10-tbs6921/
https://tvheadend.org/projects/tvheadend/wiki/TBS6981
http://blog.mohammadzadeh.info/index.php/step-by-step-guide-to Dead Post
brettser
Postby chgil » Tue Dec 03, 2013 9:21 pm
what is the command for compile???
Excuse me but i have 2 usb DTT with af9035, but not function, with tbs6981.
not i have solution
Did you have solution for me?
gilberto from italy
chgil
Postby megavega » Mon Jun 02, 2014 3:36 am
brettser Wrote:Hi
mkdir driver
cd driver
sudo make distclean
make
sudo make install
Gavin
Code worked for me too! In Ubuntu 14.04 Thanks!
megavega
