tbs 5922
tbs 5922
Postby emadplus » Wed Aug 28, 2013 5:30 pm
Hello
I'm Emad from Saudi Arabia, my english not good i hope you understand me.
I have tbs 5922 Q BOX S2
i bought it from buydvb.net and there is a problem with H.264 Codecs for some feeds channels its working but my laptop heats up too fast and freezing, CPU 100% , i tried many H.264 Codecs like elecard,divx and ffdshow on Dream DVB and Smart DVB the same problem.
No issue with regular & HD channels and 4.2.2 feeds CPU between 4-10% its works fine.
Laptop MSI
i3 2.13
ATI HD 1GB
RAM 2GB
Thanx
Edit: how i can Blind Scan fast ?
Edit: Add Pic
emadplus
Re: tbs 5922
Postby crazycat » Thu Aug 29, 2013 1:33 am
Use video codec with hardware acceleration support (DXVA). For example LAV - http://code.google.com/p/lavfilters/
Default installation support all video formats (MPEG2,H.264,VC1) and enabled DXVA.
For BlindScan use my CrazyScan or EBS Pro.
Re: tbs 5922
Postby emadplus » Thu Aug 29, 2013 2:14 am
Thank you crazycat
i uesd LAV codec and enabled DXVA the same thing cpu 95-100% :|
emadplus
Re: tbs 5922
Postby crazycat » Fri Aug 30, 2013 1:17 am
Maybe need install ATI GPU drivers ? What GPU in your notebook ?
Re: tbs 5922
Postby emadplus » Fri Aug 30, 2013 1:28 am
ATI Radeon HD5470 with 1GB DDR3 VRAM
emadplus
Re: tbs 5922
Postby emadplus » Tue Sep 03, 2013 3:57 am
any help please
emadplus
Re: tbs 5922
Postby updatelee » Tue Sep 03, 2013 9:54 am
Refer to post #4
Goto ati's site
