2 instances of dvblast
Postby savskii » Sun Aug 18, 2013 7:09 pm
Hi, Is it possible to use 2 instances of dvblast or astra ?
so i can use BOTH tuners at same time?
everytime i try launce a second instance the first one stops
thnaks
savskii
Re: 2 instances of dvblast
Postby gfi » Sun Aug 18, 2013 7:42 pm
savskii Wrote:Hi, Is it possible to use 2 instances of dvblast or astra ?
thnaks
Need more info...
Used Transponders values, how much channels You want streaming. Protocol (udp/tcp - multicast/unicast/http).
There's some limitations (network, chipset), control CPU usage with top.
gfi
Postby savskii » Sun Aug 18, 2013 8:13 pm
Hi mate,
on each transponder there is 5 channels each.
when i run :
dvblast22 -a 0 -c /home/dvblast/JSC1.conf -f 12284000 -s 27500000 -v 13 -C -Y -e -U
works fine... but when i run:
dvblast22 -a 1 -c /home/dvblast/JSC2.conf -f 11958000 -s 27500000 -v 18 -C -Y -e -U
both dont work......
savskii
Postby updatelee » Mon Aug 19, 2013 5:36 am
you cant run two applications on the same adapter (-a 0) especially at different voltages lol.
You sir need a second adapter :)
Postby savskii » Mon Aug 19, 2013 5:46 am
haha is a type error
thanks
has anyone scanned 2 tp's using astra or dvblast?
savskii
Postby updatelee » Mon Aug 19, 2013 6:37 am
:) no worries
is the config files on each of those pointing to different IP's
I honestly have little experience with multicast and the few times Ive used it I use mumudvb. multicast is wonky on my network, it locks up all wifi until I close the multicast application.
Postby atvcomm » Mon Aug 19, 2013 2:17 pm
I have 20 MOI and all working with 2 transponders
Only one problem, can't to use more of 9 channel, don't have enough CPU power
Another problems with MOI is problem with LNB power supply and splitter for more devices
I cut directly in MOI output power wire, because 2 or more MOI have problem with that
I try to stopped supply in configuration, but unsuccessful, TS discontinued error. After cutting, working fine
atvcomm
Postby savskii » Tue Sep 10, 2013 3:38 pm
hey guys, i have tryed all methods and i find maximum number of streams i can get out of MOI is 5 channels.....
I have tryed dvblast and astra with no luck runnng 2 similtaniuos occasions of same program or even running 2 diferent apps, i find the cpu gets to 90-99% as soon as i run ONE program
cheers
savskii
Return to General discussion
