Easey Install Ubuntu 10.4 Server
Postby spacedvb » Sat Aug 03, 2013 11:50 pm
best way and , I have 14 server with TBS6984 and the only way run easey install is with
version 121105 , the rest is a pain and always is error..
If you want to install stable server IPTV streamer use:
Ubuntu 10.4
TBS Drivers V121105
dvblast
decrypt-stream
spacedvb
Re: Easey Install Ubuntu 10.4 Server
Postby raid2001 » Tue Sep 01, 2015 1:31 am
howe to install driver on ubuntu 14.02 server TBS6991SE ??
raid2001
Postby raid2001 » Wed Sep 02, 2015 4:26 am
raid2001
Postby steven » Sun Sep 06, 2015 3:13 pm
Hi raid2001
In our driver package it contain the README you can have a look:
here is the detail steps:
I.1 extract linux-tbs-drivers.tar.bz2 archive:
# tar xjvf linux-tbs-drivers.tar.bz2
I.2 go to driver package directory:
# cd linux-tbs-drivers
I.3 depending on your kernel version and if the kernel is x86 or
x86_64 (check output of 'uname -a') do:
- for x86 kernel 3.x (x86 32 bit installations of kernel 3.x):
# ./v4l/tbs-x86_r3.sh
- for x86 kernel 2.6.x (x86 32 bit installations of kernel 2.6.x):
# ./v4l/tbs-x86.sh
- for any x86_64 kernel (x86 64 bit installations of Linux):
# ./v4l/tbs-x86_64.sh
I.4 build and install the driver:
# make && make install
I.5 reboot in order to load the newly installed driver:
# shutdown -r now
I.6 after reboot check that the newly installed driver is loaded correctly:
# dmesg | grep frontend
