XBMCbuntu + tbs6618
XBMCbuntu + tbs6618
Postby huntdog » Tue Jul 23, 2013 2:06 am
Hi everyone,
Im having some kind of problem with XBMCbuntu and my tvcard (tbs6618 dvb-c). It works fine after i install xbmcubuntu and its drivers, the problem is, when i shutdown the htpc and turn it on the next day the card doesnt load up.
I reboot and reboot and reboot.... and after a few tries it goes on again. What could be the problem?
If i enter bios of the motherboard sometimes it shows up connected other thimes it doesnt.... The mb is an asrock h77m.
huntdog
Re: XBMCbuntu + tbs6618
Postby steven » Tue Jul 23, 2013 6:22 pm
Hi huntdog
Would you mind using eraser to wipe the Goldfinger of TBS6618 or change the
PCI-E slot and try again.
Postby huntdog » Fri Dec 13, 2013 10:47 am
steven Wrote:Hi huntdog
Thx for the advise. I sent a mail to asrock, it was a bug on the board firmware, was fixed with an update.
But now i got another problem.
When i suspend the pc, and turn it on again, the card seems that doesnt load again. Always have to restart the pc again. Is there any workaround to fix this in ubuntu/xbmcbuntu?
huntdog
