Universal Remote with TBS8920
Postby imrankhanawan » Mon Jun 24, 2013 11:07 pm
I have TBS8920 in Windows 7 64bit and using it with DVBviewer and is working perfect.
However, I have lost the original remote that came with the DVB card. Is it possible to use the universal remote control with TBS VHID device?
I have read somewhere TBS remotes are NEC coded, I have tried to use the NEC codes but couldn't get it work.
Can some one please guide me in correct direction. I want to be able to use a universal or dreambox remote with TBS VHID device.
Thanks in advance.
imrankhanawan
Re: Universal Remote with TBS8920
Postby steven » Thu Jun 27, 2013 4:27 pm
Hi imrankhanawan
Do you know your NEC remote's every key remote code??
If you know you can have a try to modify the TBS8920VHID.inf file
and reinstall the TBSVHID driver .
;IR key list(max 0x7f)
;IR_Scancode_*: hardware ir scan code
;IR_Virtualcode_*: application shortcut key
; 0x00x x x x xx
; |->ctrl key pressed flag
; |->shift key pressed flag
; |->Alt key pressed flag
; |->keyboard(1 for keyboard, 2 for system key)
; |->Virtualcode(refer to the USB HID usage table)
HKR,"DriverData","IR_Scancode_0", 0x00010001, 0x84
0x84 is the remote key value.
Postby imrankhanawan » Sat Jun 29, 2013 4:20 am
I dont know the codes for each key,
Can we not use universal remote by using the TBSDVB remote control code. I mean, use it in a similar way as we can use dreambox remote control to control any TV, for example insert the samsung tv code into the universal code to use it with tv.
I am sure there must be another way, come on gentlemen help me with this problem.
imrankhanawan
