[ Moderator Control Panel ]
by gfi » Wed Jun 19, 2013 7:03 pm
- opkg manager is already installed in FW 1.2.
- FW 1.1 missing, due to Boxes are selling with newest FW. Have You FW 1.0 installed?
gfi
by krasserg » Wed Jun 19, 2013 8:02 pm
Yes, i have FW 1.0 installed, but i cannot upgrade to 1.2.
I trye from 8GB and 256mB card FAT32
MOI mounts the SD and see files on it.
krasserg
by gfi » Thu Jun 20, 2013 12:40 am
krasserg Wrote:Yes, i have FW 1.0 installed, but i cannot upgrade to 1.2.
Ok, Stay tuned. I'll informing You about upgrade process as soon as possible.
gfi
by krasserg » Thu Jun 20, 2013 1:21 pm
Ok!
Thanks!
krasserg
by warumnix » Fri Jun 21, 2013 3:13 pm
warumnix
by krasserg » Fri Jun 21, 2013 4:08 pm
All OK!
Please add the instructions necessary to clean the browser cache manually after the update. In chrome shows old page WUI from cache.
Perhaps this was the problem initially.
Thank you for your prompt assistance!
Thread can be closed.
krasserg
by warumnix » Mon Jun 24, 2013 5:37 pm
krasserg Wrote:All OK!
Thanks for the feedback:) Same problem with IE and Firefox...
http://www.tbsdtv.com/forum/viewtopic.php?f=92&t=8539&p=29297#p29297
warumnix
Return to General discussion
