TBS 8922 - help needed to get working!
Postby rm4405 » Mon May 27, 2013 5:17 pm
Hi all
I recently purchased a TBS8922 and I'm having some trouble getting it working on my PC - any help would be appreciated.
The computer is an Intel Core 2 Duo system with a Intel DP43BFL motherboard and 8gb RAM, running Windows 7. The card is recognised by the computer, drivers install fine, and the TBS IP software says that the card detects signal (about 50-60% strength). However, I can't find any channels, either using TBS Blind Scan, or in TBS Viewer and ProgDVB.
I tried the card in a friend's computer (an AMD system on Windows 7) using my satellite connection and it worked fine, finding channels in both TBS Viewer and ProgDVB, so I'm pretty sure there is some incompatibility with the card and my motherboard - has anyone come across this, and does anyone know how to fix it?
I've tried using exactly the same settings on my computer to the ones that worked on my friend's computer, but it's still not working. Does anybody have any bright ideas I can try?
Thanks in advance
Rob
rm4405
Re: TBS 8922 - help needed to get working!
Postby steven » Fri May 31, 2013 3:53 pm
Hi rm4405
Can you have a check that do you have installed the TBS8922 capture device in your Device management?
Postby rm4405 » Tue Jun 04, 2013 12:43 pm
Hi Steven
Thanks for getting back to me. Yes, I do have the TBS8922 TS Capture showing in Device Manager.
Thanks, Rob
rm4405
