Remote won't work in windows media centre
Postby andrew2102 » Wed May 15, 2013 6:12 pm
Hi there I purchased a TBS 6220 not long ago and I'm very impressed I installed it installed the drivers and windows media centre recognised it straight away, I didn't even considering using the software on the disc as I like windows media centre but I assumed the remote would work but it doesn't, does the remote only work in the provided software or am I missing something?
Thanks in advance!
andrew2102
Re: Remote won't work in windows media centre
Postby steven » Sun May 19, 2013 3:14 pm
Hi andrew2102
yea,you need to install a TBSVHID soft to use the remote with MCE:
http://www.tbsdtv.com/download/document ... .0.0.8.zip
Please install this and have a try again. :)
Postby andrew2102 » Tue May 21, 2013 2:01 am
Thanks just what I needed to know, working perfectly now.
andrew2102
Return to General discussion
