TBS 6981 with proliant dl380 g5
Postby bashar1aziz » Mon May 13, 2013 4:31 pm
I have purchased TBS 6981 and tried to install it in an Proliant DL 380 server with Windows 2008 Server R2, but unfortunately I had some problems, when I go to the Device Manger I can see the TBS card and it says: code 39 unable to load device driver, the driver is up to date( downloaded from TBS website).
Any help would be appreciated.
Regards,
Bashar
bashar1aziz
Re: TBS 6981 with proliant dl380 g5
Postby crazycat » Tue May 14, 2013 8:32 am
Win2008 Server R2 not have BDA subsystem, so device not work.
You can install BDA-subsystem from download (Windows Server 2008 R2 BDA patches)
Postby bashar1aziz » Wed May 15, 2013 5:53 am
Thank you, the card is now identified, but I have now another problem, TBS-IP can identify the card, signal is good, but when I use the TBS viewer and do channel scan, it found a couple of channels when I click on the one of the channels, I see nothing, black screen, I've already checked options and choose DECODER tab and I see lots of null codec. Moreover I tried to use dvb dream same problem error, lots of null (decoder).
which driver should I use with windows server 2008 r2 64 bit ?
bashar1aziz
Postby steven » Sun May 19, 2013 3:17 pm
Hi bashar1aziz
Would you mind use some TS analyse soft such as TSReader or Transedit to check that you
have got the TS stream. :)
