TBS 5925 windows 7 ultimate
Postby tumbuti » Mon May 13, 2013 12:05 pm
Good Morning all.
Which is the best driver for TBS 5925 running on windows 7 ultimate?
Should i use windows xp as most tbs 5925 applications are not running on windows 7?
Thanks in Advance.
tumbuti
Re: TBS 5925 windows 7 ultimate
Postby crazycat » Tue May 14, 2013 8:33 am
use latest driver for all windows :)
Postby tumbuti » Tue May 14, 2013 1:07 pm
crazycat Wrote:use latest driver for all windows :)
Good Morning Crazycat,
Thanks for your feedback.
Have upgraded to 1.0.1.7 driver but applications are not running.
I noticed the power supply that came with TBS 5925 is rated @ Outout DC 12V 2A.
Is this the right voltage for tbs5925?
tumbuti
Postby steven » Wed May 15, 2013 7:18 pm
Hi tumbuti
Can you give us more detail information about your problem?
kind Regards
Postby nokoflow » Fri May 24, 2013 6:49 pm
Do sombody now that the TBS 5925 works on windows 8 also?
thanks
nokoflow
Postby steven » Sat May 25, 2013 11:10 pm
nokoflow Wrote:Do sombody now that the TBS 5925 works on windows 8 also?
thanks
Hi nokoflow
We have tested it on windows 8 x86 amd x64 and it is ok. : )
Postby tumbuti » Tue May 28, 2013 1:08 pm
Hi tumbuti
kind Regards
Good Morning Steven,
When i switch on TBS 5925 the red light is on while the green light under lock blinks twice than goes off.
I carried out Crayscan on 2 different satellite that i can get in my region and graph results are the same.
satellites, SES 5 Sub sahara beam and Nilesat 201/Eutelsat 7 west A.
I have carried out the test on a number of satellites and the results are the same.
When i disconnect the satellite dish connection, the graph reading is different as shown in the snapshot below.
I carried out blind scan on SES 5 using tbs blind scan and got only 6 frequencies out of 11 frequencies under SES sub Saharan footprint>>[url]>http://www.lyngsat.com/SES-5.html[/url]
When i ran TBS Viewer am unable to lock on any of the frequnies which i got from the blindscan results>>
Below specs of PC and findings under device manager>>>
I bought am TBS 5925 in April 26th form BuyDvb and reported the issue of faulty tbs 5925 to support@tbsdtv.com on 16th May but no reply yet regarding RMA.
Am thinking of purchasing TBS 6925 but was wondering if i will have the same issue.
Thanks in Advance and please advice on any other tests that you may want me to carry out on tbs 5925.
tumbuti
Postby tumbuti » Tue May 28, 2013 3:38 pm
Hi tumbuti
kind Regards
To addon>>>
Sometimes when i switch off TBS 5925 while on TBS Viewer, my windows 7 ultimate crashes ( blue screen) and pc restarts.
Was thinking of installing windows xp to see if it is a driver issue.
Please advice.
tumbuti
Postby steven » Wed May 29, 2013 3:23 pm
Hi tumbuti
Can you have a try with this driver:
https://hotfile.com/dl/224891294/ffa7b5 ... d.zip.html
or can you send a remote connect information to support, after send the information
you can send me a PM message, :)
So we can have a remote check.
Postby tumbuti » Tue Jun 04, 2013 6:22 pm
steven Wrote:Hi tumbuti
Good Afternoon Steven,
Thanks for the driver.
Run Tbs 5925 with the driver you provided but still not working.
Tried all drivers of tbs 5925 on windows XP without any success.
I think the device is faulty.
Am still waiting for RMA (Return Merchandise Authorization) from Buydvb.
Thanks for your valued support.
tumbuti
