Diseqc problem?(Solved)
Postby switchcore » Sun May 12, 2013 4:12 am
Having problems with, what I guess, diseqc switching.
Have configured diseqc A=Thor 0.8 and diseqc B=Sirius 4.8.
When I scan for channels I get over 500 channels on Lnb A and about 14 channels on Lnb B.
I also have a hauppauge wintv nova-hd-s2 in the same computer and when I scan with that card I get over 500 channels on both lnbs.
Scanning has been done in both mediaportal and dvbviewer with the same result.
I have also tried both tuners in the 6981 card without luck.
Drivers tested is V2.0.1.5 and V2.0.1.6 on windows7 64-bit
switchcore
Re: Diseqc problem?
Postby steven » Sun May 12, 2013 8:45 pm
Would you mind direct connect Sirius 4.8's signal to TBS6981 ,Then have a scan to check
whether you can get over 500 channels.
Re: Diseqc problem?
Postby switchcore » Mon May 13, 2013 12:47 am
I have tried to connect directly from lnb B, sirius 4.8 to the 6981, like you said, and now i get all the channels, 500+
So it seems to be a diseqc switching problem.
The diseqc itself works because i have tried it on my hauppauge card and it works there.
/Jerry
switchcore
Re: Diseqc problem?
Postby steven » Fri May 17, 2013 10:57 am
Hi switchcore
Can you use our IPTools to have a check DiSEqc B's signal?
http://www.tbsdtv.com/download/document ... .0.3.7.zip
Just choose some transponder to have a check whether you can get lock.
Re: Diseqc problem?
Postby switchcore » Sat May 18, 2013 2:27 am
hi
i have tried your iptools and i have tried several transponders and they lock.
have switched back and fourth between diseqc a and b and they both lock.
but it still dont work in mediaportal
switchcore
Re: Diseqc problem?
Postby steven » Sun May 19, 2013 3:03 pm
Thanks for your test report
So this means that the card is ok.
just a soft compatible problem.For Mediaportal do you have installed this path:
http://forum.team-mediaportal.com/threa ... ts.103276/
This is path is to support DiSEqc.
Re: Diseqc problem?
Postby switchcore » Sun May 19, 2013 7:28 pm
Hadn´t seen that patch.
It works fine after installing it.
Thanks so much for the help
regards
Jerry
switchcore
