TXFIFO not empty after Timeout, tried 1000 loops!
Postby Spinaker » Thu Apr 25, 2013 1:06 pm
Intel® Core™ i5-3550 CPU @ 3.30GHz stepping 09
Gigabyte Technology Co., Ltd. To be filled by O.E.M./Z77X-D3H, BIOS F18c 03/11/2013 (Latest bios version!)
Linux streamer-s1 3.2.0-0.bpo.4-amd64 #1 SMP Debian 3.2.41-2~bpo60+1 x86_64 GNU/Linux
TBS6985 + Drivers v130318 (64bit)
01:00.0 Multimedia controller [0480]: Philips Semiconductors SAA7160 [1131:7160] (rev 02)
        Subsystem: Device [6985:0002]
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Interrupt: pin A routed to IRQ 46
        Region 0: Memory at f7d00000 (64-bit, non-prefetchable) [size=1M]
        Capabilities: [40] MSI: Enable+ Count=1/32 Maskable- 64bit+
                Address: 00000000fee0800c  Data: 41a1
Apr 25 11:54:11 streamer-s1 kernel: [160093.921258] saa716x_i2c_hwinit (0): Adapter (c000) SAA716x I2C Core 1 RESET
Apr 25 11:56:08 streamer-s1 kernel: [160209.905420] saa716x_i2c_send (0): TXFIFO not empty after Timeout, tried 1000 loops!
Apr 25 11:56:08 streamer-s1 kernel: [160209.905452] saa716x_i2c_send (0): I2C Send failed (Err=-5)
Apr 25 11:56:08 streamer-s1 kernel: [160209.905469] saa716x_i2c_xfer (0): Data send failed
Apr 25 11:56:08 streamer-s1 kernel: [160209.905491] saa716x_i2c_hwinit (0): Adapter (c000) SAA716x I2C Core 1 RESET
Apr 25 11:57:01 streamer-s1 kernel: [160263.036005] saa716x_i2c_send (0): TXFIFO not empty after Timeout, tried 1000 loops!
Apr 25 11:57:01 streamer-s1 kernel: [160263.036036] saa716x_i2c_send (0): I2C Send failed (Err=-5)
Apr 25 11:57:01 streamer-s1 kernel: [160263.036054] saa716x_i2c_xfer (0): Data send failed
Apr 25 11:57:01 streamer-s1 kernel: [160263.036076] saa716x_i2c_hwinit (0): Adapter (b000) SAA716x I2C Core 0 RESET
Apr 25 11:57:08 streamer-s1 kernel: [160270.198304] saa716x_i2c_send (0): TXFIFO not empty after Timeout, tried 1000 loops!
Apr 25 11:57:08 streamer-s1 kernel: [160270.199602] saa716x_i2c_send (0): I2C Send failed (Err=-5)
Apr 25 11:57:08 streamer-s1 kernel: [160270.199631] saa716x_i2c_xfer (0): Data send failed
Why is this happening?
Spinaker
Re: TXFIFO not empty after Timeout, tried 1000 loops!
Postby devicebusy » Tue Aug 06, 2013 9:36 pm
Same messages in log, system is ASUS Sabertooth 990FX R2.0 / AMD FX6300 / 2G ram + 2x TBS6985 + 1x TBS3102, Debian wheezy with 3.9. kernel from backports:
Linux streamer1 3.9-0.bpo.1-686-pae #1 SMP Debian 3.9.6-1~bpo70+1 i686 GNU/Linux
from debian repository:
root@streamer1:~# dpkg -l | grep linux-image
ii linux-image-3.9-0.bpo.1-686-pae 3.9.6-1~bpo70+1 i386 Linux 3.9 for modern PCs
TBS drivers are:
-rw-r--r-- 1 root root 15199793 Jul 29 10:53 tbs-linux-drivers_v130729.zip
root@streamer1:~# modinfo tbs6985fe
filename: /lib/modules/3.9-0.bpo.1-686-pae/kernel/drivers/media/dvb/frontends/tbs6985fe.ko
license: TurboSight Proprietary: www.tbsdtv.com
author: Konstantin Dimitrov <kosio.dimitrov@gmail.com>
description: TurboSight TBS 6985 DVBS/S2 frontend driver module
depends: i2c-core
vermagic: 3.9-0.bpo.1-686-pae SMP mod_unload modversions 686
devicebusy
Postby devicebusy » Tue Aug 06, 2013 9:58 pm
BTW messages are begins in the log only when i have enabled this sysctl settings:
cat /etc/modprobe.d/tbs6985.conf
options saa716x_tbs_dvb int_type=1
options saa716x_tbs_dvb verbose=1
options dvb_core dvb_shutdown_timeout=0
options dvb_core dvb_powerdown_on_sleep=0
i've never see this error before sysctl tuning
devicebusy
