CI+ ?
CI+ ?
Postby Chriz » Thu Apr 11, 2013 9:20 pm
I have a question if this card supports CAM with CI+, CI Plus ?
/Christian
Chriz
Re: CI+ ?
Postby steven » Fri Apr 12, 2013 4:44 pm
Hi Chriz
Sorry that TBS6680 do not support CI+.
Re: CI+ ?
Postby Retiree » Fri Apr 12, 2013 10:50 pm
Hi Christian,
TBS6680 has many many other problems, but supports both CI and CI+ interface. At least in my case supports Conax CAM CI+ and CI also ...
Retiree
Retiree
Re: CI+ ?
Postby crazycat » Fri Apr 12, 2013 11:57 pm
your Conax CI+ can work in legacy CI mode (if your cable provider allow) :) No more :)
Re: CI+ ?
Postby Retiree » Sat Apr 13, 2013 12:33 am
OK, clearly. But some tuners do not support CI+ interface (or CAM+ respectively), for example all Technisat tuners ...
Retiree
Re: CI+ ?
Postby Chriz » Sat Apr 13, 2013 5:27 pm
Ok, then I know. :-(
Are you planing on releasing such a card, PCIe Dual tuner DVB-C CI+ ?
Chriz
Re: CI+ ?
Postby Retiree » Sat Apr 13, 2013 11:02 pm
Christian,
read the whole thread "TBS6680 does not work", still no solution !!!. This card can still be used only as one tuner. I still believe that the hardware is a good product, but the Windows driver and dynamic library for CI interface is still not resolved!
Retiree
