Dvblast unable to query frontend
Postby ubbyy » Thu Mar 28, 2013 3:45 pm
Hi guys
I have a problem I have on a server 3 tuners, including a tbs6991
I install the driver after installation sees tuners but can not be used dvblast
I moved to another server where he installed lafel just do.
iptv@iptv:~$ sudo dvblast -c iptv1.cfg -f 11474700000 -s 280000000 -v 18
DVBlast 2.2 (git-2.2-24-gd720688)
warning: restarting
debug: compiled with DVB API version 5.6
error: unable to query frontend
lspci -v
04:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
Subsystem: Device 6991:0001
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at feb00000 (64-bit, non-prefetchable) [size=1M]
Capabilities: <access denied>
Kernel modules: saa716x_tbs-dvb
iptv@iptv:~$ dmesg | grep dvb
[ 7.055798] DVB: registering new adapter (SAA716x dvb adapter)
[ 7.632710] DVB: registering new adapter (SAA716x dvb adapter)
iptv@iptv:~$ dmesg | grep frontend
[ 7.632578] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6991 DVBS/S2 frontend)...
[ 8.344724] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6991 DVBS/S2 frontend)...
iptv@iptv:~$ ls /dev/dvb/
adapter0 adapter1
ubbyy
Re: Dvblast unable to query frontend
Postby Souldream » Fri Mar 11, 2016 2:39 am
Problem for sure is you try to run a "dvblast" compiled with 5.10 DVB api ( Linux 4.0 ) but driver are not !
Souldream
Postby Souldream » Fri Mar 11, 2016 2:41 am
version.h from "drivers" shipped :
#define DVB_API_VERSION 5
#define DVB_API_VERSION_MINOR 3
But if you look your include kernel used to compile dvblast :
#define DVB_API_VERSION_MINOR 10
Souldream
