Can't use szap-s2 or scan-s2
Postby martin » Mon Mar 11, 2013 5:32 pm
I have problems bringing my TBS6981 to work. Downloaded newest driver from the website and installed as described in the READMIE_TBS6981 (64 bit version), but neither szap-s2 or scan-s2 really make it to operate with the satellite dish. With a set top box it works fine, so the dish can be excluded from the problem.
dmesg output seems ok:
[ 16.095497] cx23885_dvb_register() allocating 1 frontend(s)
[ 16.397972] DVB: registering adapter 0 frontend 0 (TurboSight TBS 6981 DVBS/S2 frontend)...
[ 16.425821] cx23885_dvb_register() allocating 1 frontend(s)
[ 16.506366] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6981 DVBS/S2 frontend)...
szap-s2 seems to hang:
# ./szap-s2 -c ../astra_szap-s2.conf -p -r -S 0 \\\\\\\"BBC\\\\\\\"
reading channels from file \\\\\\\'../astra_szap-s2.conf\\\\\\\'
zapping to 3 \\\\\\\'BBC\\\\\\\':
sat 0, frequency 11597 MHz V, symbolrate 22000000, coderate auto, rolloff 0.35
vpid 0x00a3, apid 0x005c, sid 0x2742
using \\\\\\\'/dev/dvb/adapter0/frontend0\\\\\\\' and \\\\\\\'/dev/dvb/adapter0/demux0\\\\\\\'
^C
and this is what scan-s2 puts out:
# ./scan-s2 -vvv -a 0 ../astra_scan-s2.conf
API major 5, minor 3
scanning ../astra_scan-s2.conf
initial transponder DVB-S 10773000 H 22000000 5/6 35 QPSK
initial transponder DVB-S 11778000 V 27500000 3/4 35 QPSK
initial transponder DVB-S2 11362000 H 22000000 2/3 35 8PSK
>>> tune to: 10773:hC56M2O35S0:S0.0W:22000:
DiSEqC: uncommitted switch pos 0
DiSEqC: e0 10 39 f0 00 00
DiSEqC: switch pos 0, 18V, loband (index 1)
DiSEqC: e0 10 38 f2 00 00
DVB-S IF freq is 1023000
>>> tuning status == 0x01
>>> tuning status == 0x03
WARNING: >>> tuning failed!!!
>>> tune to: 10773:hC56M2O35S0:S0.0W:22000: (tuning failed)
>>> tuning status == 0x00
I have no clue how to go on at this point, you can help me?
Many Thanks,
Martin
PS: You wishe lspci output, so here it comes:
06:00.0 Multimedia video controller [0400]: Conexant Systems, Inc. CX23885 PCI Video and Audio Decoder [14f1:8852] (rev 04)
Subsystem: Device [6981:8888]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 19
Region 0: Memory at f7c00000 (64-bit, non-prefetchable) [size=2M]
Capabilities: [40] Express (v1) Endpoint, MSI 00
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <2us, L1 <4us
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+
Flags: PMEClk- DSI+ D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
Capabilities: [90] Vital Product Data
Product Name: \"
End
Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [200 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed+ WRR32+ WRR64+ WRR128-
Ctrl: ArbSelect=WRR64
Status: InProgress-
Port Arbitration Table [240] <?>
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=01
Status: NegoPending- InProgress-
Kernel driver in use: cx23885
Kernel modules: cx23885
uname -a:
Linux server 3.2.0-38-generic #61-Ubuntu SMP Tue Feb 19 12:18:21 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
martin
