What Linux distro does the MOI use
Postby martinhj » Wed Feb 20, 2013 6:54 pm
Can anyone give me an indication what distirbution of Linux the MOI uses....will it be possible to customise this?
I am thinking in terms of setting up a MOI as a Mythtv slave backend. It would be very popular if it could be done I am sure!
Martin
martinhj
Re: What Linux distro does the MOI use
Postby steven » Thu Feb 21, 2013 2:33 pm
Hi martinhj
Thanks for your advice, MOI use 2.6.31 kernal ,And maybe next version of MOI we will add
grahp output such as using Mythtv. :D
Postby martinhj » Thu Feb 21, 2013 8:50 pm
I trust by next version of MOI you mean the next software update and I wouldnt have to buy a new harware version having just pre-ordered one to play with!
Will it be possible for an experienced user to update the kernel version and install other software on the moi?
Martin
martinhj
Postby marcelp1 » Mon Mar 18, 2013 3:58 pm
steven Wrote:Hi martinhj
Hi Steven,
so what distro is that for the less linux litarate? Debian, Ubuntu .........?
marcelp1
Postby updatelee » Tue Mar 19, 2013 8:23 am
almost guarantee if its not open embedded then its custom. You wont see any major distro like ubuntu or debian on embedded devices because it just doesnt make any sense.
Postby steven » Thu Mar 21, 2013 9:25 am
Hi Steven,
Hi marcelp1
It is not Debian or Ubuntu,just a standard linux version. :)
Postby Angel » Wed Apr 10, 2013 8:40 pm
Actually it is an embedded Linux distro, named Buildroot.
http://buildroot.uclibc.org/
Angel
Return to General discussion
