Tbs5680 on Synology DS1812+ (x86)
Postby Progaar » Thu Feb 14, 2013 3:13 pm
When will this driver be available?
Thanks,
Peter
Progaar
Re: Tbs5680 on Synology DS1812+ (x86)
Postby updatelee » Fri Feb 15, 2013 3:03 am
What processor does it run? What os?
Postby Progaar » Fri Feb 15, 2013 3:39 am
Hi Lee,
It runs on a Intel x86 ATOM Cedarview processor of 2,13Ghz (2 cores + HyperThreading)
Os is Synology DSM 4.1, based on a Linux kernel. I don't know the exact distribution.
Thanks,
Peter
Progaar
Postby updatelee » Fri Feb 15, 2013 11:24 am
well there is already tbs5680 linux x86 drivers available. so... are you asking how to compile them?
Postby Progaar » Fri Feb 15, 2013 2:46 pm
Hi Lee,
This is the answer from TBS last week. Question was the same.
" thanks for your feedback, we are currently looking into this and will do our best to support it very soon.
Thank you for your patience."
So, I don't know if it is only a matter of compiling. Can you point me to the source of this x86 drivers? I'll give it a try.
Thnx,
Peter
Progaar
Postby updatelee » Fri Feb 15, 2013 10:40 pm
Postby Progaar » Sun Feb 17, 2013 1:37 am
Thanks Lee!
Progaar
